This option is used to create attachments from existing elements such as rigid
patches or rigid spiders. You can specify the elements to be absorbed, or you can
allow HyperMesh to search and find the suitable elements
in the model.
In the Connector Browser, right-click and select .
The Create Attachment Connectors dialog opens.
In the Selection field, choose either Manual or
Automatic from the drop-down list.
If the FE Config field, select either Rigid Spider or
Rigid Patch from the drop-down list.
In the Filter Entity field, use the Elements selector to
select the appropriate elements.
Click Create to start the process.
