Create attachments from features for holes.
This option is used to create attachments by selecting a part and providing hole
tolerances, or selecting a node on the hole and providing hole tolerances. HyperMesh identifies the holes based on the selection and
creates attachments at the location.
In the Connector Browser, right-click and select .
The Create Attachment Connectors dialog opens.
In the Search Type field, select Hole from the drop-down
list.
For Selection, choose either Automatic or
Manual.
If you selected Manual in the previous step, use the Location
Entity selector to the select the number of nodes.
In the Filter Entity field, use the Parts selector to
select the appropriate parts.
Enter a maximum and minimum dimension and a tolerance value.
In the Attachment Control field, use the Attachment
Control selector to select the appropriate attachment
control.
Alternatively, you can right-click on this field and create an attachment
control directly.
Click Create to start the process.
