Create a Set
  1. From the Advanced Query dialog, click the Create Set button.
    The Create Group dialog is displayed.
  2. Enter a name in the Group label field to create the set (group).
    Note: A default label is provided.
  3. Click OK.
    A set (group) of entities which have been queried is created.
    Tip: You can also create a set (group) of entities using the Set panel.
