Exporting and Saving a Query Table
  1. From the Query panel, click Export.
    The Output File dialog opens.
  2. Select the directory to which you want to save the text file.
    Note: The initial directory displayed is the present working directory.
  3. Enter a file name in the File name field, or accept the default file name, "result".
    Tip: If you want to open the file in Excel, give the file a .csv extension.
  4. Click Save.
