Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Front suspension supports the wheels in the front with the help of a solid axle. The front suspension stabilizes the
vehicle to the road and helps to absorb the bumps of the road. There are two types of front suspension used in the
Truck Library.
The steering system mechanism permits the driver to guide the truck along the rod and turn right or left as desired.
The steering mechanism includes the steering wheel which the driver regulates the steering gear which converts the
rotary motion of the wheel into straight line motion.
The stabilizer bar helps to control body roll on turns. The Assembly Wizard allows selection of two types of stabilizer
bars, single piece and two piece.
This section explains briefly on how to build a rear suspension model.
For example, select the Rear Dual axle suspension as the Rear Suspension and select the two
axle driveline system in the Rear end of truck section to build a Rear suspension model
using the Assembly Wizard. After building the model, the following model is displayed in the
graphics area.
Events
It is recommended that a simple event to be added, such as Kinematics and Compliance
Analysis, and then the model be simulated as soon as it is built. Events create motions and
forces in the model which make the system move. Most events add additional parts to the
model to perform the simulation. The following steps outline how to add an event to the
previously built model.
Click Analysis > Task Wizard, to begin adding an event to the model.
Select the required Rear end task from the drop-down menu.
Figure 3.
Note: To learn more about the Ride Analysis, Roll Analysis, Steering Analysis, and
Static Load Analysis refer to the Rear Suspension Analysis Tasks topic.
Select Finish to exit the Task Wizard.
Figure 4.
Reports
To view the generated reports, follow the steps shown in the Reports topic.
