Create a Frequency vs. Time Plot
  1. From the HyperGraph 3D toolbar, click the Waterfall icon, .
  2. Under Plot type:, select Frequency from the first drop-down menu and Time from the second drop-down menu.
  3. Under Data curves:, manually enter a p#w#c#.vector curve reference for Response=, or press Shift and left-click an RPM curve in HyperGraph.
Or
  1. Use the curve selector.
    1. Click the curve selection button, , in the Response text box to display the Response dialog.
    2. Choose a curve from the tree and click Select.
    3. You can also click Preview to view the curve before selecting it.
    4. Click Close to close the Curve dialog.
  2. Under Waterfall slices:, select Number: and enter the number of slices for the waterfall plot.
Or
  1. Select Step size: and enter a step size based on the time vector of the response curve.
  2. Click Apply.
