Attach a Note to a Curve
  1. From the Notes panel, create a new note by clicking Add under the Note list.
Or
  1. Select a note from the list or pick one from the window.
  2. Click the Attach To tab.
  3. Select Curve as the attachment.
  4. Pick a point on a curve.
Or
  1. Use the Find point controls to position the note leader on a curve.
  2. For complex plots only, select Attach to real or Attach to imaginary.
    The note is displayed with a leader pointing to the curve.
  3. Or, select Place note on curve point to display the note directly at the curve point.
