Reference a Datum Plane Intersection from an XY Plot Window
  1. From the Select application drop-down menu, select HyperGraph.
  2. From the Define Curves panel, add a new curve.
  3. Under Source, change the curve type to Math.
  4. In the x= or y= fields, enter p#w#d#.vector to reference the planes intersection of the curves.
    The vector is either X or Y to select the values along the plane’s length or height. For example, p1w1d1.y selects the plane’s local Y values for the first datum plane in window 1 of page 1.
