Edit Legend
Legend
Fixed Scale displays a global maximum and minimum value in the legend for the time steps HyperGraph 3D has already processed.
Dynamic Scale changes the legend with respect to the maximum and minimum values of each time step or simulation.
Position
Select the position of the legend within the animation window.
Values and colors
Numeric format
Fixed displays the legend values in a fixed format.
Scientific displays the legend values in scientific format.
Numeric precision
You can increment the current value from 1 to 12 decimal points.
Number of levels
Displays more or less contour bands along with their respective ranges. The minimum number of bands you can display in a legend is 2; the maximum is 32.
Reverse levels
Reverses the legend values assigned to the contour bands.
Interpolate
Interpolates the colors in between the two colors that you select. After clicking Interpolate, use the legend within this dialog to select a color to interpolate from and a color to interpolate to. When you select Interpolate, HyperGraph 3D displays contour colors for each frame based on the linearly interpolated values between the zero value in the undeformed shape and the solver reported values.
Legend file
Open
Opens a previously saved legend in Tcl format.
Save
Saves the current legend in Tcl format.
Save options
Select any of the options listed to save them along with the current legend.
  • Position
  • Colors, levels, values
  • Value format
  • Header/Footer
  • Font attributes allows you to save the current font settings.
Header
Displays the legend header. To remove the header, deselect the check box. To enter a new header, highlight the existing text, type in a new header and click Apply.
Click the font button, , to change the font style and size.
Title
Displays the title of the legend. The title reflects the settings used to generate the contour and cannot be changed.
Click the font button to change the font style and size.
Values
Click on a color to select a new color from the color palette.
Click on the value to set a user-defined value. The number is displayed in bold face style to indicate the custom setting.
To reset the number, click on the number and erase all digits. The legend values between two custom settings are linearly interpolated.
Minimum/Maximum
Displays the maximum and minimum legend values. Deselect the option to remove the minimum and maximum values from the display.
Local minimum/Local maximum
Displays the local minimum and local maximum of a particular time step or simulation. The local maximum and minimum are displayed in parentheses next to the global maximum and minimum. This option is available only in transient mode with a static legend.
Footer
Displays the legend footer. To remove the footer, deselect the check box. To enter a new footer, highlight the existing text, type in a new header and click Apply.
Default
Resets the default legend properties.
Apply
Click Apply to apply the changes made to the legend.
OK
Click OK to exit the Edit Legend dialog.
Close
Click Close to exit the dialog.
