Change Axis Attributes
  1. From the HyperGraph 3D Axes panel, select the X, Y, or Z Axis tab or pick the axis from the HyperGraph 3D window.
  2. Edit the attributes you want to modify.
  3. Click Apply.
    The changes are applied to the axis.
