Use the Report tool, formerly known as Automated Reporting Director, to create and export Document and Presentation
reports from within the HyperWorks session.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
From the Session Browser, select the pages or windows
that you want to publish to PowerPoint.
From the bottom portion of the browser, under Basic, select
Publish Page or Publish
Windows, respectively.
While the page or window is selected, right-click in the Session Browser to access the following context menu options:
Create Tag
To create a tag for a new entity in the Session Browser, right-click on the entity and
select Create Tag. The following dialog
opens:
Enter a tag name and select its format from the drop-down
menu.
Tag Table
To view, rename, delete, or change the format for tags while in
the Session Browser, right-click and select
Tag Table from the context menu. See the previous Tag Table
definition for more information.
Quick Publish
Transfers data to PowerPoint from the HyperWorks Desktop session with respect to what is
selected/highlighted in theSession Browser
(the publishing settings will be ignored). Quick Publish always
create new pages in the PowerPoint file. If you are on aHyperWorks Desktop page, HyperGraph notes are tagged and no
windows are selected for publishing; the page must be selected
so that the notes will be published.
Publish Settings
See Publishing Settingsto learn more about the EMF and MPT
file format option available when publishing a session.
