Modify a HyperWorks Desktop Session and Publish to an Opened or Saved PPT
If you have added pages to your HyperWorks Desktop session, or have edited existing data in your session, you can transfer these modifications to an open PowerPoint file.
  1. From the menu bar, select File > Publish > PowerPoint.
Or
  1. From the Standard > PPT menu, select Publish to PowerPoint to display the Publishing PowerPoint dialog.
  2. From the Publishing PowerPoint dialog, select Opened PPT.
  3. From the drop-down menu, select the opened PPT that you want to publish to.
Or
  1. Choose Select PPT on Disk to open an existing PowerPoint file.
  2. Click Synchronize to update existing PowerPoint slides with only the images that have been changed in your session.
    Note: If you click Publish, new slides will be added to your PowerPoint presentation.
  3. Click Synchronize when Publishing to add new pages to PowerPoint and also synchronizes images, animations, and headers in previously created PowerPoint pages.
