vidIVideo UseTolerance
Sets if the tolerance is on.
vidIVideo_handle UseTolerance on
HyperWorks Tcl Modify
This command sets if the tolerance is on. Tolerance is the allotted difference in timing between two videos. If the timing between two videos is greater than the tolerance, the second video (or third or fourth, and so on) will not play the frame(s) corresponding with that specific time.
Note: For this function to work, at least two videos must be on the page.
on
A true or false value.
True
Tolerance on.
False
Tolerance off.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle Video;
Video UseTolerance true;
Keywords
  • HyperWorks
  • Tcl
  • Video
  • Modify
