vidIVideo SetMeasurePoint2X
Sets the x coordinate of the second point of a static measure.
vidIVideo_handle SetMeasurePoint2X index x
HyperWorks Tcl Modify
This command sets the x coordinate of the second point of the measure object referenced by the given index.
index
The index of the measure to be changed.
x
The x value (in pixels) that you want to make the second measure point.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle Video;
Video AddMeasure static;
Video SetMeasurePoint1X 1 400;
Video SetMeasurePoint1Y 1 68;
Video SetMeasurePoint2X 1 600;
Video SetMeasurePoint2Y 1 68;
Video DrawMeasure;
