vidIVideo IsTolerance
Determines if the tolerance is on.
vidIVideo_handle IsTolerance
HyperWorks Tcl Query
This command finds if the tolerance is on. Tolerance is the allotted difference in timing between two videos. If the timing between two videos is greater than the tolerance, the second video (or third, fourth and so on) will not play the frame(s) corresponding with that specific time.
Note: For this function to work, at least two videos must be in the page. If the tolerance is on, true is returned. Otherwise, false is returned.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle Video;
Video IsTolerance;
Success (a true or false value) or an error message is returned.
Keywords
  • HyperWorks
  • Tcl
  • Video
  • Query
