poISystem SetUserDefined
Converts a system to a user-defined system.
system_handle SetUserDefined state
HyperView Tcl Modify
This command sets the system to be of the type "user-defined". This command is used for internal purposes only! It is highly recommended that it not be used in custom scripts, as it may become obsolete in future versions.
state
This argument can have a value of "true" or "false".
To convert/set a system as a "user-defined" system:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSystemHandle sys1 “UserSystem 2”
# set it to true
sys1 SetUserDefined true
# set it to false
sys1 SetUserDefined false
hwi CloseStack
Returns a non-zero value if there is an error.
