poISweepCtrl SetSweepPattern
Sets the axisymmetry setting.
poISweepCtrl_handle SetSweepPattern
HyperView Tcl Modify
This command sets the axisymmetry setting.
To set the axisymmetry setting:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSweepCtrlHandle sweep_handle
# 10 instances along z-axis with a coverage of 170 degrees
sweep_handle SetSweepPattern “z 10 170”
hwi CloseStack
None.
