poISubcase GetDerivedSimulationSubcase
Returns the ID of the original subcase which was used to create this particular simulation of the derived subcase.
subcase_handle GetDerivedSimulationSubcase simidx
HyperView Tcl Query
This command returns the ID of the original subcase which was used to create this particular simulation of the derived subcase.
simidx
The simulation index within the derived subcase.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
set scid [result_handle AddSubcase];
result_handle GetSubcaseHandle subcase_handle $scid
subcase_handle SetDerivedType “superposition”
subcase_handle AppendSimulation 3 0;
subcase_handle AppendSimulation 4 1;
set a1 [subcase_handle GetDerivedSimulationSubcase 0];
set a2 [subcase_handle GetDerivedSimulationSubcase 1];
# The variable a1 will have a value of 3 and the variable a2 will have a value of 4
hwi CloseStack
Returns "0" if an invalid simulation index is passed.
