poIQueryExtremeRule SetExtreme
Sets the query extreme to the advanced query.
rule_handle SetExtreme queryExtreme
HyperView Tcl Modify
This command is used to set the query extreme to the advanced query.
queryExtreme
Accepts only the following rule types: "TopN" or "BottomN".
To set the query extreme to the advanced query:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations “current” “current”
advancedQuery_handle SetQueryRule "[rule_handle GetID]"
advancedQuery_handle SetQuery “entity.id entity.value”
hwi CloseStack
This command returns HW_Error, if an invalid string is passed to the query extreme.
