poIPostManager SetGlobalPropertyValue
Sets the global property value.
poIPostManager_handle SetGlobalPropertyValue property value
HyperView Tcl Modify
This command sets the value to the global property.
property
The name of the available global property.
value
Value must be "Yes" or "No".
To set the value to a global property:
hwi OpenStack
session_handle GetClientManagerHandle manager_handle Animation;
manager_handle GetGlobalPropertyList
manager_handle SetGlobalPropertyValue  “Convert 2nd order elements to 1st order elements” “Yes”
hwi CloseStack
This command returns HW_error, if an invalid property name is passed.
