poIMeasure GetID
Gets the measure ID.
poIMeasure_handle GetID
HyperView Tcl Query
This command retrieves the measure ID.
Error
Returns the measure ID, or Null_ID (0) if an error occurs.
Adds a dynamic curve for this measure, using the specified y-axis, to the given plot client.
Adds a dynamic curve for all entities in the current measure group, using the specified y-axis, to the given plot client.
Adds an element to the measure.
Adds the given entity to the measure from the specified model and pool.
Adds the entity set used as the "from" set.
Adds the entity set used as the "to" set.
Adds the given node of the current/specified model to the measure.
Adds a static curve for this measure, using the specified y-axis, to the given plot client.
Adds a static curve for all entities in the current measure group, using the specified y-axis, to the given plot client.
Adds a marker to the measure.
Creates the measure item.
Gets the calculated average for all measure items.
Gets the measure base time (for relative measures only).
Gets the measure text color index.
Gets the measure display option setting.
Gets a list of measure display modes.
Gets a list of measure entities.
Gets the measure entity type.
Gets the list of measure entities in a measure group.
Gets a handle to an hwIFont interface for the font of the measure.
Gets the "from" selection set type.
Gets a list of measure items which make up this measure.
Gets the measure label.
Gets the calculated maximum for all measure items.
Gets the calculated minimum for all measure items.
Gets the measure result system ID.
Gets the review mode for the measure group.
Gets the "to" selection set type.
Gets the measure type.
Gets the possible measure types.
Gets a list of values for all items in the measure.
Gets the measure visibility.
Highlights the "from" and "to" selections for the measure item.
Gets if the measure item is dynamically linked to a curve or not.
Removes the given measure item.
Sets the measure base time (for relative measures only).
Sets the measure text color.
Sets the measure display mode.
Sets the measure label.
Sets the measure analysis system.
Sets the review mode for the measure group.
Sets the measure type.
Sets the measure visibility.
Unlinks the live connection between this measure item and the curve to which it's connected.
ON THIS PAGE
HyperView Tcl Query
ON THIS PAGE
