poICFD_rake SetNumberOfSeeds
Specifies the number of the seeds in the rake used for the stream integration creation in the CFD Plot/Streamlines panel.
poICFD_rake_handle SetNumberOfSeeds num_seeds
HyperView Tcl Modify
This command specifies the number of the seeds in the rake used for the streamline creation in the CFD Plot/Streamlines panel and returns success (if successful).
Note: In the case of an "Area" rake, the number of seeds actually created could be smaller than the value specified by this command, since the real number of seeds cannot exceed the number of elements in the 2D part, which is specified when the rake is defined. The Num_seeds argument must be a positive integer.
num_seeds
The number of seeds in the rake.
To specify the number of the seeds in the rake to be "20":
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetCFDCtrlHandle CFD_handle
CFD_handle GetRakeHandle CFD_rake_handle [CFD_handle AddRake “line”]
CFD_rake_handle SetNumberOfSeeds 20
hwi CloseStack
Error
Returns HW_InvalidArgs if the number of seeds specified is not a positive integer.
