hwIDataFile SetFilename
Sets the current file in the data file handle.
hwIDataFile_handle SetFilename filename
HyperWorks Tcl Modify
This command sets the current file being used in the data file handle.
filename
The file path of the desired file. If the file path has spaces in it, the input must be within quotation marks, " ", or curly braces, {}.
hwi GetSessionHandle sess;
sess GetDataFileHandle df c:/demos/mv_hv_hg/plotting.adams/wiper.req;
df SetFilename C:\demos\test.abf
Error
Success (a true or false value) or an error message is returned.
Keywords
HyperWorks
Tcl
Data File
Query
