hide model
Hides all or parts of a model.
hide model all
hide model <id>
Arguments
- all
- Hides all models.
- <id>
- Hides models based on ID. For example,
(1,2,4)
For example, (1-3,5,7).
Examples
hide model all
hide model 5
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
View manipulation.
Perform actions on XY files.
hide model all
hide model <id>
(1,2,4)
For example, (1-3,5,7).hide model all
hide model 5
