mark
Marks entities on the active model.
mark entity ?argument? ?argument?
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Open files.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
View manipulation.
Perform actions on XY files.
