mark component
Marks components.
mark component all
mark component clear argument
mark component <dictionaryrange>
mark component displayed
mark component <range>
mark component select
Arguments
all
Mark all components.
clear
Clear all components.
all
Clear all components from mark.
dictionaryrange
Clear components from mark with names between {[<start>,} <end>\].
displayed
Clear displayed components from mark.
<range>
Clear by component ID.
For example, 1-3,8,13-20,25?,3*.
"Rigid Barrier", Bump??, back*
hinge, handle
select
Clear selected components from mark.
dictionaryrange
Mark components with names between <start> and <end>.
displayed
Mark displayed components.
<range>
Mark components by ID.
For example, 1-3,8,13-20,25?,3*. Or, based on labels (wildcards supported) and label lists: "Rigid Barrier", Bump??, back*, hinge, handle.
select
Mark components by selection, interactively selected from the modeling window.
Clear mark components between a defined start and end range:
mark component clear dictionaryrange "BEAM: DRIVE-SHAFT" "BEAM: RAIL-CONN-BACK"
Mark all components:
mark component all
Mark displayed components:
mark component all
