Command Files
The HWC log file contains a record of the HWC Console activity. It can be turned on/off using the Log to File context menu option in the HWC Console.
Alternative, you can record the HWC commands in Tcl syntax into a Tcl file, where the HWC commands have the “hwc” wrapper as a prefix. The file location is handled as it is for the HWC command file (see HWC Command File Location).
The default filename for the HWC log file is hw_command.hwc. This file is saved by default to your working directory if you select the Log to HWC File option. Use the environment variable HW_COMMANDFILE_DIR to change the default save location.
- Append
- Any existing command file is appended (default).
- Overwrite
- Any existing command file is overwritten instead of appended.
- Unique
- A new command file is generated with the name hw_command_<timestamp>_<username>.hwc.
