config variable
Set user-defined variables.
config variable <variable name> <value>
config variable <variable name> <file>
config variable <variable name> <directory>
Arguments
<variable name>
Enter a variable name. Select from one of the following options:
<value>
Enter a value for the variable.
<file>
Select a file from the file browser.
<directory>
Displays the directory browser.
Examples
Add the variable variable1 and assign it a value of 20:
config variable variable1 20
