config section
Set planar and spherical section cut options.
config section planar <name>=<value>
config section spherical <name>=<value>
Arguments
planar
Define the planar section cut options.
base=<value value value>
Enter user-defined x, y, and z coordinates to check the current position of the section cut.
clipabove=<true/false>
Select true or false.
clipelements=<true/false>
Display the elements of the clipped part of the model.
crosssectiononly=<true/false>
Display a cross section of the section cut.
deformable=<true/false>
Make the deform mode deformable.
grid=<true/false>
Display the gridlines.
gridlinespacex=<value>
Enter a value to change the x position of the graphical manipulator on the grid line grid.
gridlinespacey=<value>
Enter a value to change the y position of the graphical manipulator on the grid line grid.
gridtext=<true/false>
Display the grid line text value in the modeling window.
gridtextprecision=<1-10>
Increment the current grid line text value from 0 to 10 decimal points.
normal=<value value value>
Specify a plane normal to the screen by picking a base node on the model.
orientation=<3nodes/normaltoscreen/xaxis/yaxis/zaxis>
Define the orientation. Options include:
  • 3nodes
  • normaltoscreen
  • xaxis
  • yaxis
  • zaxis
sectioncolor=<RBG/label>
Change the section cut color by entering RGB values or selecting a color from the list.
showsectioncolor=<true/false>
Display the section cut color.
visibility=<true/false>
Display the section cut in the modeling window.
width=<section width>
Adjust the width of the cross section by entering a value.
spherical
Define the spherical section cut options.
center=<value value value>
Enter the x, y, and z coordinates of the base point of the section cut.
centernode=<node id>
Allows you to adjust the position of the base point of the section cut to the center node.
clipinside=<true/false>
Displays the cross section of the section cut inside the sphere.
Allow the section cut to be deformed, along with the components, during animation.
radius=<value>
Enter a value to specify the radius of the spherical section cut.
sphere=<true/false>
Displays a sphere.
Define spherical section cut options:
config section spherical visibility=true showsectioncolor=true sectioncolor=Cyan clipinside=true centernode=60
Default values specified by this command will be used by all spherical and planar section cuts.
