HMRES_readbinaryint2()
Reads a 2-byte integer from a binary file opened with HMRES_openinputfile(). It pays attention to the cross-platform flags and does a conversion on the number, making it understandable to the machine on which the program is running.
int HMRES_readbinaryint2(FILE *file);
HyperMesh hmreslib Function
file
The binary file containing the 2-byte integer to be read.
The value of the 2-byte integer.
None.
