HMRES_convertbuffertodouble()
Converts a buffer containing floating point information from one machine type to another machine type.
double HMRES_convertbuffertodouble(int fromformat, int toformat, char * buffer);
HyperMesh hmreslib Function
fromformat
The format of the "from" buffer.
toformat
The format to which the "from" buffer should be converted.
buffer
A pointer to the buffer being converted.
Returns the converted floating point value.
None.
