HMRES_readbinaryfloat()
Reads a floating-point number from a binary file which opened with HMRES_openinputfile(). It pays attention to the cross platform flags and does a conversion on the number, making it understandable to the machine the program is running on.
float HMRES_readbinaryfloat(FILE * file);
HyperMesh hmreslib Function
file
The binary file containing the floating-point number to be read.
The value of the floating-point number.
None.
