HMRES_readbinaryint()
Reads a binary integer from a binary file opened with HMRES_openinputfile(). It pays attention to the cross platform flags and does a conversion on the integer, making it understandable to the machine the program is running on.
int HMRES_readbinaryint(FILE * file);
HyperMesh hmreslib Function
file
The binary file containing the integer to be read.
The value of the integer.
None.
