HMIN_filelocator_continuereading()
Indicates if the last of a specified entity is read.
int HMIN_filelocator_continuereading(void * filelocatorptr, int filelocator, FILE * file);
HyperMesh hminlib Function
locatorptr
A pointer to the block of file locators.
filelocator
The index into the block of file locators.
File
The entity to be read.
1, if it has not read through to the end of the block.
0, if it has reached the end of the block.
None.
