HMIN_filelocator_calculaterange()
Calculates the range between file locators.
void HMIN_filelocator_calculaterange(void * locatorptr, int startlocator, int endlocator);
HyperMesh hminlib Function
locatorptr
A pointer to the block of file locators.
startlocator
The index into the locator block at the beginning of the range to be calculated.
endlocator
The index into the locator block at the ending of the range to be calculated.
None.
