*includemacrofile()
Include the contents of the passed macro file.
*includemacrofile (filename)
HyperMesh Utility Menu Command
filename
The name of the macro file to include.
This command allows you to specify the name of a macro file to be read in. When this command is used with the new empty row arguments for the *createbutton and *createtext commands, it allows you to create macros that may be plugged into the Utility menu.
