*createentitypanel()
Allows you to interactively select a single entity from a command file.
*createentitypanel (entity type message)
HyperMesh Utility Menu Command
entity type
The type of entity which will be placed into the mark.
message
The message to display to the user.
To select a single element:
*createentitypanel(elements,"Select the element")
