Use the Vector tool to set options for a vector plot.
Individual vector components, shear, and complete resultants
can be plotted for vector based results. From the Results toolbar, click
Vector
Note: You can also select from the Results menu.
Attention: The Envelope utility is not intended for use with vector plots. If
it is used with a vector plot, HyperView will simply draw the
last loadstep in the derived loadstep list.
