Overlay Result Display
  1. Open the Vector panel in the following ways:
    • From the Results toolbar, click Vector .
    • Select Plot > Vector from the Results menu.
  2. From the Vector panel, under Result display control, activate the Overlay result display option.
    Overlays the vector, tensor, and contour results in the same window.
    Note: If all results are displayed simultaneously, available memory may be affected.
