Manage the Legend Display
  1. Open the Vector panel in the following ways:
    • From the Results toolbar, click Vector .
    • Select Plot > Vector from the Results menu.
  2. From the Vector panel, click the Legend tab (located in the middle of the panel).
  3. Activate the Max check box and enter the value to be assigned to the highest color in the contour plot.
    The new value is also changed in the Values section of the Edit Legend dialog.
    Note: If a value entered for threshold Max is invalid, it will not be applied and the panel will be updated to reflect the actual state.
  4. Activate the Min check box and enter the value to be assigned to the lowest color in the contour plot.
    Note: If a value entered for threshold Min is invalid, it will not be applied and the panel will be updated to reflect the actual state.
  5. For Multiplier, enter the multiplier for scaling all the result values.
  6. Click the Edit Legend button.
    The Edit Legend dialog opens, where you can change legend properties.
