Change the Vector Head
  1. Open the Vector panel in the following ways:
    • From the Results toolbar, click Vector .
    • Select Plot > Vector from the Results menu.
  2. From the Vector panel, click the Display tab (located in the middle of the panel).
  3. Select a display option for the vector head from the first drop-down menu.
    • Arrow - Displays the vector head as an arrow
    • None - Displays the vector head as a straight line.
  4. Select an attachment option for the vector head from the second drop-down menu.
    Option Description
    Tail Attaches the tail of the vector head to the reference point.
    Tip Attaches the tip of the vector head to the reference point.
    Center Attaches the center of the vector head to the reference point.
