Change the Vector Color by Value
  1. Open the Vector panel in the following ways:
    • From the Results toolbar, click Vector .
    • Select Plot > Vector from the Results menu.
  2. From the Vector panel, click the Display tab (located in the middle of the panel).
  3. Select Value from the Color by drop-down menu.
    The Edit Legend button becomes enabled in the Legend tab.
  4. From the Legend tab, click Edit Legend.
    Modify the legend values and colors in the Edit Legend dialog.
