Plot Browser Context Sensitive Menu
From the Plot Browser, right-click on a highlighted entity to access the following context sensitive menu options.
Current Project Menu
Expand All
Expands all entities in the current project, exposing all items nested within the folder.
Collapse All
Collapses all entities in the current project.
Page Context Menu
Expand All
Expands all pages in the session, exposing all items nested within the folder.
Collapse All
Collapses all pages in the session.
Select All
Selects all page titles in the session.
Note: When in Toggle Sync Mode, , the Select All option is unavailable.
Plot Window Context Menu
Expand All
Expands all plot windows in the session, exposing all items nested within the window.
Collapse All
Collapses all plot windows in the session.
Select All
Selects all plot windows in the session.
Select All in Page
Selects all plot windows on the page.
Paste
Pastes a copied window.
Autofit Curves
Applies Auto Fit to the curves in the selected plot window.
Note: When in Toggle Sync Mode, , the Select All and Select All in Page options are unavailable.
Single and Multiple Curve Math Menus
Select All
Selects all curves in the session.
Select All in Page
Selects all curves on the page.
Select All in Window
Selects all curves in the window.
Isolate
Isolate displays only the selected curve(s), turning their display state to on, and turning all other curves off. You can isolate per window, across pages, or across the session.
Isolate Only
Similar to Isolate, except that it also affects curves other than the selected curve. This turns off ALL displayable curves except for those selected. This action can be applied per window, across pages, or across the session.
Reverse Isolate
Reverse Isolate hides the selected curve and displays only the non-selected curves. This action can be applied per window, across pages, or across the session.
Reverse Isolate Only
When more than one curve is selected, Reverse Isolate hides the selected curves and displays only the non-selected curves. This action can be applied per window, across pages, or across the session.
Turn On
Displays a curve in the graphics window.
Turn Off
Hides a curve in the graphics window.
Cut
Removes the curve from the Plot Browser and deletes it from the current session.
Copy
Copies the selected curve. To paste it into the browser, select the window name from the browser, right-click and select Paste.
Delete
Deletes the curve from the session.
You can also select a curve from the Plot Browser and delete it by pressing the Delete keyboard key.
Extreme Curve
Filters maximum or minimum contributors based on a design aspect from a set of curves.
After plotting curves, right-click in the Plot Browser and select Extreme Curves from the context-sensitive menu.
Figure 1. Extreme Curves
Extreme Curve Type menu
If Maximum is selected, the Top N curves are displayed based on the value set in the Display Top/Bottom N Curves field.
If Minimum is selected, the bottom N curves are displayed based on the value set in the Display Top/Bottom N Curves field.
Search in Trimmed X Range
Selected by default.
Trim X Range by
Choose between Value or Index. For both options, enter values in the Start Value or Index and End Value or Index fields.
Display Extreme Curves
Choose between Trimmed or Original.
Trimmed
The plotted extreme curve is trimmed by the user-defined range.
Original
Keeps the total curve as an extreme curve.
Consider Visible Curves Only
Ignores hidden curves in the extreme curve math.
Curve Correlation
Outputs a correlation metric in the form of notes on the plot using correlation algorithms. These functions are used to calculate a correlation metric between test and CAE data. Sprague-Geers Combined Metric (SGCM) and Weighted Integrated Factor (WIFac) are supported.
Sprague-Geers
The Sprague-Geers metric is a simple integral comparison metric that includes both magnitude and phase errors, which are calculated independently and then combined to give a comprehensive error. The error calculation can be biased towards either the measured time history (test) or the computed (CAE) time history, with the former being the most common.
Figure 2. Curve Correlation - SGCM
The Weighted Integrated Factor method (WIFac) is used in the auto industry for crash simulations. This metric is associative and calculates the agreement between two signals. This is advantageous in situations where the experimental data is known to have significant error. WIFac is weighted by the absolute maximum of the function values. This weighting has the effect of scaling local differences to increase the effect of errors at high magnitude function values.
Figure 3. Curve Correlation - WIFac
From the Curve Correlation dialog, you can leave the default settings or edit the options as needed. Click Plot to display notes with the correlation metrics in the plot window.
Figure 4. Curve Correlation - Notes
Reference Curve
Use the file browser to select reference curves or enter enter a list of ID’s (for example, 1-4).
Correlation Curve IDs
Enter an individual ID or a list of IDs (for example, 5-7).
Correlation Type
Supported methods include SGCM and WIFac.
SGCM Display Options
Combined Metric
Display combined metric value.
See SGCM in the Templex and Math Reference Guide.
Sprague-Geers Combined metric
Display Sprague-Geers combined metric value.
Magnitude difference
Display magnitude difference value.
Phase Difference
Display phase difference value.
Reference Curve Label
Display reference curve label.
Correlation Curve Label
Display correlation curve label.
Wifac Options
Peak
Peak score.
See wifac in the Templex and Math Reference Guide.
Peak Time
Peak time score.
Wifac
The weight of the WIFac.
Enable Mirroring
Mirror function used for negative values.
Mirroring Simultaneously
Mirror reference and correlated curves at the same time.
Auto Mirror Factor
Value of mirroring factor; default value is 0.5.
Wifac Display Options
Wifac
Display the WIFac value.
Peak
Display the peak value.
Peak Time
Diplay peak time value.
Total
Display total value.
Add Stackmath Operation
Create a math stack on a curve. From the dialog, use the filter bar, , to filter the math functions to apply to a curve. Once a math operation is applied to a curve, the curve is redrawn per the math function without creating any duplicate curves. The Name/Value entity editor in the dialog displays the parameters for the math function, which you can edit as needed. The parameters displayed are based on the selected math function.
Figure 5. Add Stackmath Operation
Apply
Adds an operation to the curve and keeps the dialog open for the next math operation to apply.
OK
Adds the selected math function to the curve and closes the dialog.
Cancel
Closes the dialog.
Stackmath provides the following advantages:
  • Easy-to-use and intuitive workflow through the Plot Browser to add and remove math operations as a stack.
  • Avoids editing complicated math functions.
  • Provides high-performance math calculations.
Single Curve Math
Performs a math functions on a single curve, which results in the creation of a new curve.
Included in the name of the new curve is the name of the math function. For example, if you choose to perform the Derivative function on curve 1 and there were currently three curves in the session, the new curve would be named c4:Derivative--Lower Torso. The new curve is also added to the Curve list on the Define Curves panel.
Multiple Curve Math
Performs math functions on multiple curves, which results in the creation of a new curve. The name of the math function is also included in the name of a new curve. For example, c7:Resultant.
You can choose to get the sum or resultant of multiple curves.
If you have the Vehicle Safety Tools loaded, the Filter and Injury menu options are also included on the context sensitive menu. Please see the Vehicle Safety Tools topic for more information.
Vector Context Menu
Select All
Selects all vectors displayed in the tree.
Select All in Page
Selects all vectors displayed on the page.
Selects all vectors displayed in the window.
Note: When in Toggle Sync Mode, , this menu is disabled.
You can also add your own options to the context sensitive menu using the *BrowserContextMenuItem() preference file command.
