HyperGraph 2D
Powerful data analysis and plotting tool for all types of CAE data.
HyperGraph 2D is a powerful data analysis and plotting tool with interfaces to many popular file formats. Its sophisticated math engine is capable of processing even the most complex mathematical expressions. HyperGraph 2D combines these features with high-quality presentation output and customization capabilities to create a complete data analysis system for any organization.
Benefits
HyperGraph 2D supplies design, test, and analysis engineers with an intuitive plotting and data analysis package. HyperGraph 2D’s combination of an easy-to-use interface and robust suite of automation tools enables engineers to view and analyze data more efficiently, which:
  • Minimizes the manual effort and time required to generate plots. The automatic plot builder generates a family of fully labeled plots from data file(s), using file header and channel information.
  • Eliminates repetitive tasks. Plot macros capture and automate common math expressions.
  • Eliminates repetitive plot generation. Report templates can capture and automate the building of entire pages of data plots.
  • A fully customizable interface. Customize the interface and the tools to fit any engineering environment.
  • A customizable library of mathematical functions. You can add custom defined math functions to Altair's robust math library.
  • Provides automation tools for efficient data analysis and report generation.
  • Overlays sequential test and simulation results for visualization and analysis.
  • Directly exports active session reports to HTML or PowerPoint XML.
