CORA and ISO-18571
Use the HyperGraph 2D Curve Correlation dialog to find correlation metrics in the form of notes using different correlation algorithms. The CORA and ISO-18571 functions calculate the correlation metric between test and CAE data.
CORA
The Correlation Analysis (CORA) calculates correlation metric between CAE and Test Data signals in the form of time history. Includes both corridor and cross correlation, which are calculated independently and then combined to give a comprehensive error. The error calculation can be biased towards either the measured time history(Test) or the computed (CAE) time history, with the former being most common.
CORA(CORRIDOR)
The Corridor metod (CR) calculates correlation between two signals by means of corridor fitting. The error calculation can be biased towards either the measured time history (Test) or the computed (CAE) time history, with the former being most common.
CORA(CROSS CORRELATION)
The cross correlation metod (CRCR) calculates correlation between two signals by calculating phase shift, size and progression. The weighted some of these three values gives total cross correlation rating.
ISO-18571
The ISO metric combines different types of algorithms to get reliable and robust assessment between CAE and Test Data signals in the form of time history. Includes corridor, phase, magnitude, and slope which are calculated independently and then combined to give an overall ISO rating. The error calculation can be biased towards either the measured time history (Test) or the computed (CAE) time history, with the former being most common.
Open the Curve Correlation Dialog
  1. From the file menu, click File > Open > Plot to open the Create Curves by File dialog.
  2. From the Open File dialog, navigate to your working directory and select a file to open and plot some curves.
  3. From the Plot Browser, select a reference curve, right-mouse click, and select Curve Correlation.
  4. From the Correlation Type drop-down menu, select a correlation method.
  5. Select Cora to display the following options.
  6. Retain the default settings or change the defaults per your requirements and click Plot.
    Notes are displayed with the correlation metrics in the plot window.
Input Options
Reference Curve
Select reference curves through the Plot Browser or enter a list of ID’s. For example, 1-4.
Correlation Curve IDs
An individual ID or list of IDs. For example, 5-7.
Correlation Type
Supported methods include:
  • SGCM
  • Wifac
  • Cora(cross correlation)
  • Cora(Corridor)
  • Cora
  • ISO-18571
Cora Parameters
Evaluation Interval Parameters
A_THRES
Threshold to set the start of the interval of evaluation. Varies between 0 and 1.
B_THRES
Threshold to set the end of the interval of evaluation. Varies between 0 and 1.
A_EVAL
Automatically calculated interval of evaluation. Varies between 0 and 1.
B_DELTA_ENDis
Shortens the end of the interval of evaluation if it is calculated automatically. Varies between 0 and 1.
Tmin/ Tmax
Defines the starting and the ending time of the evaluation interval.
Corridor Parameters
K
Exponent factor (progression) for the calculation of the corridor rating.
G-1
Weighting factor of the corridor rating.
a0
Width of the inner and outer corridor.
b0
Width of the outer and outer corridor.
a_sigma
Factors of the standard deviation to widen the inner corridor.
b_sigma
Factors of the standard deviation to widen the outer corridor.
Cross Correlation Parameters
D_MIN
Calculates the interval of evaluation. Varies between 0 and 1.
D_MAX
INT_MIN
Minimum overlap of the interval. Varies between 0 and 1.
K_V
Exponent factor (progression) of the calculation of the progression rating, V.
K_G
Exponent factor (progression) of the calculation of the size rating, G.
K_P
Exponent factor (progression) of the calculation of the phase shift rating, P.
G_V
Weighting factors of the progression rating.
G_G
Weighting factors of the size rating.
G_P
Weighting factors of the phase shift rating.
G_2
Weighting factors of the cross-correlation method.
Signal Parameters
MIN_NORM
The limit to start special treatment of secondary axis. Varies between 0 and 1.
Y_NORM
Type of calculation of Y_NORM; options include extremum or value.
WF_NORM
Normalization of the weighting factors; options include YES or NO.
Select ISO-18571 to display the following options:
Figure 3.
ISO-18571 Parameters
A_THRES
B_THRES
A_EVAL
B_DELTA_END
Tmin/ Tmax
This keyword defines the starting and the ending time of the interval of evaluation.
Corridor Parameters
K
W_Z
a0
b0
a_sigma
b_sigma
Cross correlation Parameters
W_P
Weighting factor of the phase score.
W_M
Weighting factor of the magnitude score.
W_S
Weighting factor of the slope curve.
Signal Parameters
MIN_NORM
The limit to start special treatment of a secondary axis. Varies between 0 and 1.
Y_NORM
WF_NORM
Cora Display Options
Phase(P)
Display the phase value.
Progression(V)
Display the Progression value.
Size(G)
Display the Size value.
Total Correlation Rating(C2)
Display the Total Correlation Rating value.
Total Cross Correlation Rating(C1)
Display the Total Cross Correlation Rating value.
Corridor Rating
Display the Corridor Rating value.
Reference Curve Label
Display the Reference Curve label.
Correlation Curve Label
Display the Correlation Curve label.
ISO-18571 Display Options
Phase Rating(EM)
Display the Phase Rating value.
Rank
Display the rank value.
Magnitude Rating(EP)
Display the Magnitude Rating value.
Corridor Rating
Slope Rating(ES)
Display the Slope rating value.
