hgthp
Description Supports Does Not Support
Reads PAM-CRASH and PAM-CRASH 2G THP files (time history files generated by the solver) into HyperGraph 2D.
Also reads ASCII files generated by exporting curves from PAMVIEW.
hgthp can be run from the command prompt to convert THP files into Altair Binary Files (ABF files).
PAM-CRASH 2003 THP files are also supported.
No ESI license is required to use this reader.
The PAM-CRASH 2G and PAM-SAFE options.
Solid Elements
  • Only the first seven variables of Table A in the PAM-CRASH 2G Notes Manual, Plot Output 5, (output qualifiers SXYZ and EPLE).
  • Shell and Membrane Elements
  • Only the first 14 variables of Table A in the PAM-CRASH 2G Notes Manual, Plot Output 7, (output qualifiers MXYZ to STRA).
  • Beam and Bar Elements Only the first fourteen variables of Table A in the PAM-CRASH 2G Notes Manual, Plot Output 13, (output qualifiers FAXI to RTN2).
  • Results for nodal time histories, transmission sections, airbags, airbag chambers, airbag walls, materials, contacts, and rigid walls are also supported.
The PAM-STAMP option.
