Dyna External Readers
Option Description Supports
ABSTAT Airbag statistics.
Reads airbag and blocked materials statistics from LS-DYNA files into HyperGraph 2D. The data read in is sorted by time steps specified in the input file.
Volume, pressure, internal energy, input mass flow rate, output mass flow rate, mass, temperature, and density.
BNDOUT Boundary condition forces and energy. x, y, z force
DEFGEO Deformed geometry file. The NASBDF file (Nastran Bulk Data) is created whenever the DEFGEO file is requested.
DEFORC Discrete elements. x, y, z force
ELOUT Element data. Beam
  • axial force resultant
  • s shear resultant
  • t shear resultant
  • s moment resultant
  • t moment resultant
  • torsional resultant
Stress Shell
  • xx, yy, zz stress
  • xy, yz, zx stress
  • plastic strain
Brick
  • xx, yy, zz stress
  • xy, yz, zx stress
  • effective stress
  • yield function
Strain Shell
  • xx, yy, zz strain
  • xy, yz, zx strain
  • lower surface strain
  • upper surface strain
GCEOUT Geometric contact entities. Translational Components
  • x force, y force, z force
Rotational Components
  • x moment, y moment, z moment
GLSTAT Global data. Always obtained if SSSTAT file is activated. kinetic energy
internal energy
total energy
ratio
stonewall-energy
spring and damper energy
hourglass energy
damping energy
sliding interface energy
external work
x, y, z velocity
time step
Element ID controlling time step
JNTFORC Joint force file. x, y, z force
x, y, z moment
MATSUM Material energies. kinetic energy
internal energy
hourglass energy
x, y, z momentum
x, y, z rigid body velocity
total kinetic energy
total internal energy
total hourglass energy
NCFORC Nodal interface forces. x force, y force, z force
NODFOR Nodal force groups. x, y, z force
NODOUT Nodal point data. x, y, z displacement
x, y, z velocity
x, y, z acceleration
x, y, z rotation
x, y, z rotational velocity
x, y, z rotational acceleration
RBDOUT Rigid body data. x, y, z displacement
x, y, z velocity
RCFORC Resultant interface forces. x, y, z force
RWFORC Wall forces. normal
x, y, z force
SBTOUT Seat belt output file.
SECFORC Cross section forces. x, y, z force
x, y, z moment
x, y, z center
area
resultant force
SLEOUT Sliding interface energy. secondary energy
main energy
SPCFORC SPC reaction forces. x, y, z force
x, y, z moment
SSSTAT Subsystem data.
SWFORC Nodal constraint reaction forces (spotwelds and rivets). axial force
shear force
