Apply Style
Select and apply attributes of the current plot to either every plot on every page or to every plot on the current page.
From the Tools menu, select Apply Style or right-click on the plot window context menu and select HG Apply Style.
From the drop-down menu under Pre Selection, select Current Page, All Pages or Last Selection.
Current Page
Applies the attributes of the current plot to the other plots on the current page.
All Pages
Applies the attributes of the current plot to the plots on every page.
Last Selection
Applies the attributes of the current plot to the previously selected curve.
The following attributes can be selected from the dialog. Place a check mark in the box to select the attribute that you want to apply. Upon opening the dialog, attributes that already have a check mark next to them are selected by default.
When applying curve styles, the attributes of the first curve in the active HyperGraph window are applied to the first curve in the selected window. Similarly, the attributes of the second curve in the active HyperGraph window are applied to the second curve in the selected window, and so on. However, if the selected window has more curves than the active window, the extra curves are not modified.
Plot
Background color
Frame color
Gridline color
Zero line color
Bar gap (Disabled if the current plot is not a bar chart).
Bar stacking (Disabled if the current plot is not a bar chart).
Complex axes (Disabled if the current plot is not a complex plot).
+/- 180 Phase constraining (Disabled if the current plot is not a complex plot).
Legend
Font
Border thickness
Leader position
Color
Location
Visibility
Header/Footer
Primary font
Secondary font
Tertiary font
Color
Alignment
Visibility
Axes
Apply to: Primary horizontal, Primary vertical, All secondary
Attributes: Label, Label font, Tic font, Color
Formatting: Axis scaling, Min, Max, Tic method, Increment, Number of tics, Number of grids, Numeric format, Numeric precision, Autofitting, Fit to range
Curves
Line style
Line thickness
Line color
Symbol
Symbol color
Symbol increment
Bar fill pattern - Disabled if the current plot is not a bar chart.
Notes
Font
Border thickness
Color
Alignment
Page Title
Font
Visibility
The following options are located on the bottom of the dialog:
Selects all the options on the dialog.
Deselects all the options on the dialog.
Reverses the selection for each option. For example, a selected check box becomes unselected.
Apply
Applies the selected options to the current page or all pages (whichever you have selected).
OK
Applies the selected options to the current page or all pages (whichever you have selected) and closes the dialog.
Close
Closes the dialog.
