dads_graph
- Description
- Converts a DADS binary result file to a .mrf, .abf, or .tab file.
- Usage
- To run from the command prompt:
View new features for HyperGraph 2D 2021.
HyperGraph can read the following types of plot data files:
The user interface provides you with a consistent look and feel when you are working in any of the HyperWorks Desktop applications.
The HyperGraph 2D menus provide quick access to panels and tools.
From this menu, select one of four plot types: XY Plot, Bar Chart, Complex Plot, or Polar Plot. XY Plot is the default plot type.
The Curves menu allows you quick access to commonly used panels and tools. The Curves menu options change, depending on the selected plot type (XY Plot, Bar Chart, Polar Plot, and Complex Plot).
The Annotations menu provides quick access to the Axes, Legends, Headers and Footers, and Notes panels. The panels available on the Annotations menu are the same for all plot type options.
From the Tools menu, you can access panels to plot statistics and retrieve individual point data.
Replace Filenames overwrites one plot data file with another plot data file in HyperGraph 2D windows.
Allows you to create and edit Templex functions.
Register import templates, external readers, external functions, and export templates in the current session or add them to the current preferences.mvw file.
The HyperGraph 2D external readers read both binary and text files.
DAC files can be imported to and exported from HyperGraph 2D.
Select and apply attributes of the current plot to either every plot on every page or to every plot on the current page.
Within HyperWorks Desktop, Templex metadata can be used at any time.
Create Shear-Moment-Torque (VMT) or Potato plots for subcase screening.
Use the RAD2NOISE dialog to create an input file based on your inputs.
Synchronize windows that contain animation results in different units and/or begin at different time steps.
From the Preferences menu, you can define file export settings and access the Options panel.
From the HyperGraph 2D modeling window, right-click to display the HyperGraph 2D context-sensitive menu.
The HyperGraph 2D toolbars provide quick access to commonly used panels and tools.
The Tab Area is the portion of the graphical user interface that contains the browsers, utilities, and other functionality not shown in the panel area.
The HyperGraph Plot Browser is located in the tab area sidebar and allows you to view the HyperGraph plot structure.
From the HyperGraph 2D NVH menu, the following options are available.
The Vehicle Safety Tools (VST) is a collection of over 200 macros, Templex functions, and external functions for use by a vehicle safety engineer.
The Model Identification Tool, known as MIT, is a profile in HyperGraph 2D for fitting test data from frequency- and amplitude-dependent bushings to analytical models.
Discover HyperGraph 2D and HyperGraph 3D functionality with interactive tutorials.
Powerful data analysis and plotting tool for all types of CAE data.
HyperGraph 3D offers a 3-D plotting environment that is fully integrated with HyperWorks, for managing, reviewing, and analyzing 3-D plots such as waterfall, surface, and 3-D line data.
Supported solvers in HyperGraph.
HyperGraph help for HyperWorks.
ON THIS PAGE
ON THIS PAGE
