Designate a part or surface(s) on your model for the bottom die.
The bottom die is a stationary tool that is used as a
reference for all auto-positions. The location for the bottom die is always below the
blank.
Select an operation, then from the tool set that appears, select the
Bottom Die.
On the guide bar, choose Part or
Surfaces.
If you choose Part, on the model, select an option from
the table below based on your desired result, and then click to confirm.
If you choose Surfaces, on the model, select the
surface(s) you want to designate as the bottom die, and then click to
confirm.
Note: If you modify the blank thickness, you must reconfigure the tools created
by offset.
Define the stroke, velocity, and Coulomb friction coefficient.
In the microdialog, to set the stroke value to the closed position of
the tools, select
. To specify a value, select the pencil tool
, type in a value, and press Enter.
Note: If you define the stroke value to be larger than the
auto-calculated or closed position, the open position of the tool
automatically repositions to match the stroke value to prevent a
collision with the bottom die.
To define the Coulomb friction coefficient, in the microdialog, enter a
value next to the icon
Click to confirm.
